You may not have completed the upgrade and update according to the specified procedure initially, skipping some steps, which led to this issue. Please refer to the specific procedure here:
viewtopic.php?t=6809
Before starting the NAS, remove the disk to enter the initialization process.
If you have installed an M.2 SSD on F2-423 as TOS target, the method is different for. Please refer to:
viewtopic.php?t=7179
If prompted with 'Delete' or formatting during installation, do not proceed, as this will result in data loss. Instead, if no prompt appears, you can complete the TOS reinstallation without affecting the data on the disk.
If during the installation process it prompts you to 'delete' or format, do not proceed, as this will result in data loss. Instead, if it does not prompt you, you can complete the TOS reinstallation without affecting the data on the disk.
