New Disk and TRAID
prejer
France
New Disk and TRAID
Post by prejer »
Morning,
I have a new NAS, a T12-450
first installation with 6 disks
ans now i wanrt to add my 6 other disk.
the NAS is free, nothing inside,
How do I restart the installation from the beginning, but now with all 12 disks ?
Thank' in advance
Re: New Disk and TRAID
You can refer to Method B in the following link: viewtopic.php?t=423
prejer
France
Post by prejer »
RyanYang wrote: ↑15 Nov 2025, 11:11 You can refer to Method B in the following link: viewtopic.php?t=423
Thank's for that, but not mentionned T12-450 in the Method !
As long as your TOS is not installed on an M.2 NVMe SSD, the method for reinstalling the system for this model can still be used.
prejer
France
Post by prejer »
RyanYang wrote: ↑15 Nov 2025, 16:44 As long as your TOS is not installed on an M.2 NVMe SSD, the method for reinstalling the system for this model can still be used.
Yes I understand, but how can I view where TOS is installed, what's the problem if TOS is on my NVme SSD ?
prejer wrote: ↑15 Nov 2025, 14:44
True, It says ALL models and then lists a couple of exceptions.
With nvme models there is an internal reset switch which must be pushed to allow the standard initialisation to be available. Otherwise it will just continue to boot from the nvme installed o/s.
For clarity: Can you confirm you wish to do a complete re-install or do you wish to expand the existing disk array(s)?
prejer wrote: ↑15 Nov 2025, 16:58
After the installation is complete, you can go to the disk page in the TOS control panel. The system will mark which disk is the system disk and you can modify it.
prejer
France
Post by prejer »
Hello and thank you for your reply.
This is a new NAS that I'm installing.
I only received 6 disks initially, and now that I have the other 6 with TRAID,
I can only add them one at a time !
So I might as well reinstall from scratch.
Erasing everything isn't a problem, there's nothing on it yet !
The volume is being built with disk 7 added (only 35%).
Can I shut down the NAS while the volume is bein
prejer
France
Post by prejer »
Can I shut down the NAS while the volume is bein in construction !
Sorry for the late reply. During the array reconstruction process, you can choose to power off the NAS. After restarting, it will continue from the previous progress.
Return to “Initialization”
