Access to TOS6 impossible
Phildefer
France
Post by Phildefer »
Hi all,
Since yesterday I’m not able to load the TOS6 webpage. I don’t understand why. Before that everything was ok and I didn’t change anything. I have this message : ERR_ADDRESS_UNREACHABLE still I can see the NAS with TNAS PC.
Could you help me please it’s urgent;
Thx.
Re: Access to TOS6 impossible
Have you tried logging in via TnasPC?
Have you confirmed the IP address shown in TnasPC is actually the correct IP?
Frustrated Beta Tester!!!
Phildefer
France
Post by Phildefer »
Yes and it is the right IP and the connection via tnas pc works …
Phildefer
France
Post by Phildefer »
Besides all Docker accessible via internet work well too; My only problem is the connection in local with a browser.
Phildefer
France
Post by Phildefer »
My Nextcloud works well too.
viewtopic.php?t=8035
Based on your description, we initially suspect that excessive usage is causing the blockage. You may try restarting the NAS.
If you can successfully restore the NAS operation, you might consider updating to the new TOS6. There is a new feature related to this in the update.
1. Added cgroup control policies to achieve reasonable allocation of CPU and memory resources.
Phildefer
France
Post by Phildefer »
Finally I have found the solution. It was due to my browser (Brave). After an update the access to local network had been disabled.
