TOS 6.0.673 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.500 or later versions.
Note: If your TOS version does not meet the requirements, please first check the update conditions for TOS 6.0.530.
Here, we sincerely thank user jpeckinp、rfbjr、sianderson、tanktarta、obvious、Gremlin、kai、nale88、magnus4ever、StephenNaylor, Lexand others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed the issue that WebDAV shared folders could not be mounted via IPv6 addresses after system reboot.
2. Fixed the issue that Debug log packages could not be downloaded when they were too large.
3. Fixed the issue that an error message might appear when opening the terminal in TOS desktop.
4. Fixed the issue that the power on/off schedule might not work under certain conditions.
5. Fixed the issue that hardware information on the Overview page was not aligned properly in some language environments.
6. Fixed the issue that cloud drives might fail to mount properly under certain conditions.
7. Fixed the issue that storage pools could not be created properly on hard disks that had previously installed other operating systems.
8. Fixed some issues that occurred when regular users used Dual Backup and Surveillance.
9. Fixed some issues related to shared folders.
10. Fixed some issues related to network interfaces.
11. Fixed some issues related to file manager.
12. Fixed some issues related to LDAP domains.
13. Fixed some issues related to virtual disks.
14. Fixed some issues related to security.
What's new:
1. Added cgroup control policies to achieve reasonable allocation of CPU and memory resources.
2. Added the pprof tool in Debug mode.
3. Added support for the new generation of TNAS models.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.021.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.3.057 for Android:
https://download2.terra-master.com/TNAS ... .3.057.apk
TNAS Mobile for iOS: Download from the iOS App Store.
powerQ
Singapore
Re: TOS 6.0.673 (X86) is Released for Update
Post by powerQ »
Update done! TOS 6 is running way smoother and more stable now – big thanks to the TM team!
billyBob
Switzerland
Post by billyBob »
upgrade from .648. This is a major difference. @powerQ is correct, way smooth. Feels like a different machine. Very responsive.
liability
Australia
Post by liability »
Updated from 6.0.6.50.
It seems to work fine, but then so did 6.0.6.50.
Edit - the web GUI does seem to load its pages a lot quicker.
Something odd: (All devices running Tos6-650)
I have updated 2 devices (both fn-221 based). Neither are set to 'auto-download'.
Click on "Download and Update"
Observe the "unzipping" countdown clock.
Reaches zero and ....... nothing.
Refresh browser page > Control Panel closes
Re-open control panel > System
Now I see "check for updates". Click on that and the process follows through with "unzip" and re-boot.
My 3rd device (F2-424) is set to 'auto-download updates' but it does not seem to actually perform the download until prompted.
None of these devices have "system event" notifications enabled (due to constant interruptions from indexing processes) so push notifications of updates are not received (I presume that is the reason, anyway). Maybe Update notifications should be another process that is separate from routine 'System event' notices. Not everyone uses this forum and, as has been seen in the past, admins might be blissfully unaware of available updates.
Frustrated Beta Tester!!!
For systems that use UPS support pointed to a TNAS UPS server:
UPS support does not automatically re-enable after update.
(Observed on 2 devices)
{The ups server itself, does re-enable automatically}
Claus
Germany
Post by Claus »
Still not running properly. After repeatedly shutting down and restarting for the second time, the md0_raid5 process runs for hours. F424Max with 4 x 22 TB Ironwolf drives.
FredMutter
France
Post by FredMutter »
liability wrote: ↑22 Apr 2025, 16:47 Edit - the web GUI does seem to load its pages a lot quicker.
Indeed.
For me also the UI seems to be much faster :o
seb
France
Post by seb »
Thanks for your work and this update. I still have an issue with notifications since upgrading to TOS 6 and I didn't find a post about it.
I can't edit notification settings and when I want to send a test email, I'm logged out and I don't receive the mail.
Is there a fix for that? Or is it a known issue that will be fixed in a future update?
Thanks.
GevinKe
Post by GevinKe »
seb wrote: ↑22 Apr 2025, 21:18 Hello,
Thanks.
Hi! We’ve forwarded the issue to the product team for thorough verification. We will promptly share the verification results and solution with you once available.
