[Help] Web-DAV Access (remote)
Hausmeier
Greenland
Post by Hausmeier »
I have activated the webdav service in TOS6. Then I opened the http-Port (8800) in my Fritz!Box to have a remote access on webdav in a webbrowser. But this doesn't work. Neither does it in Windows Explorer.
Any ideas?
Thanks in advance.
Re: [Help] Web-DAV Access (remote)
I recommend trying WebDAV connection tools such as FileZilla, WinSCP, or RAIDrive.
Hausmeier
Greenland
Post by Hausmeier »
Ok, thanks for your reply and sorry for my late answer. Well I gave it a new port - then I could log in via browser but after entering my credentials it said "not found". Then I tried WinSCP and FileZilla where it didn't work at all. Any ideas?
You may need to check if your network environment meets the requirements for remote access.
You need a public IP address that can be accessed remotely, and configure DDNS to map the corresponding port.
How to set up DDNS: viewtopic.php?t=433
How to use WebDAV: viewtopic.php?t=6441
How to map ports: viewtopic.php?t=7522
Additionally, you can refer to the FTP remote access method:viewtopic.php?t=1133
If you have already mapped the port but still cannot log in, you can edit the shared folder and check the WebDAV mount permissions for the shared folder.
Return to “File Services”
