How to Access TNAS via WebDAV on Mac and Windows
SMB, AFP, NFS, FTP, WebDAV, Rsync
TMnight
Post by TMnight »
Applicable Models:
All TNAS models
Applicable Versions:
TOS 4/5/6
MacOS
1.After logging into the TOS system, click "Control Panel" > "Network Services" > "File Service," then enable the WebDAV service.
2.Click the "Go" menu at the top of the screen, then select "Connect to Server" from the dropdown menu.
3.In the "Connect to Server" window that appears, enter your WebDAV server address and port number (HTTP: 8800, HTTPS: 474), then click "Connect," as shown in the image below:
4.Choose "Registered User" as the connection type, enter your TOS username and password, and finally click the "Connect" button to complete the connection.
Windows
Using WinSCP:
1.Visit the WinSCP website to download and install WinSCP: https://winscp.net/eng/index.php
2.Open WinSCP and click "New Site."
3.In the "File Protocol" dropdown menu, select WebDAV.
4.Enter the correct local IP/Public IP/domain name, port number (HTTP: 8800, HTTPS: 474), username, and password. Click the "Login" button to complete the operation, as shown in the image below:
Using RaiDrive:
1.Visit the RaiDrive website to download and install RaiDrive: https://www.raidrive.com/download.
2.Open RaiDrive and click the "Add" button.
3.In the Storage section, select NAS and choose WebDAV.
4.Follow the red prompt box instructions to enter the correct local IP/Public IP/domain name, port number (HTTP: 8800, HTTPS: 474), username, and password. Click the "Connect" button to complete the operation, as shown in the image below:
Remote Access Notes:
To connect to the NAS via WebDAV using a public IP or domain name, make sure to correctly map the WebDAV port numbers on your router (HTTP: 8800, HTTPS: 474).
bs8
Re: How to Access TNAS via WebDAV on Mac and Windows
Post by bs8 »
I connect, even from the internet and I can see the file and folder structure. But! It is impossible to write, and sometimes even impossible to read.
How can I make all this finally work?
Moreover, your certificates for webdav are INACTIVE.
My system: F2-223, TOS ver. 6.0.650
TMeric
Post by TMeric »
bs8 wrote: ↑22 Mar 2025, 17:09 I connect, even from the internet and I can see the file and folder structure. But! It is impossible to write, and sometimes even impossible to read.
Are you logged in as a superuser?
bs8
Post by bs8 »
Yes, I'm connecting with administrator rights. This is my only user in the system who has all the rights.
GevinKe
Post by GevinKe »
bs8 wrote: ↑22 Mar 2025, 21:36 Yes, I'm connecting with administrator rights. This is my only user in the system who has all the rights.
Please verify whether the permission settings for the folder on the NAS are correct. Additionally, let us know the operating system of your computer.
If you are using a Windows system, please try connecting with a different tool.
bs8
Post by bs8 »
A webdav folder has been added to the public folder settings. There in the folder settings it is "enabled" for "*" (if I understand correctly - "*" for any client? You don't specify what that value is anywhere). For the administrator account, of course read/write is allowed.
My system is Windows 11 pro. For some reason other webdav connects without any other utilities. It does not connect to TNAS. Connection via third-party utilities is possible (as I already said), but writing is impossible.
GevinKe
Post by GevinKe »
bs8 wrote: ↑23 Mar 2025, 13:47 A webdav folder has been added to the public folder settings. There in the folder settings it is "enabled" for "*" (if I understand correctly - "*" for any client? You don't specify what that value is anywhere). For the administrator account, of course read/write is allowed.
Hello, please provide the client you are using and its version number. We will forward this information to the product team for verification and get back to you as soon as possible.
Previously, we encountered compatibility issues with certain client versions, so we recommend trying a different version to see if the issue persists.
bs8
Post by bs8 »
GevinKe wrote: ↑23 Mar 2025, 18:01 Hello, please provide the client you are using and its version number. We will forward this information to the product team for verification and get back to you as soon as possible.
My client devices:
1. Windows 11 pro 24H2 build 26100.3476
2. MacOS Sequoia 15.3.1
3. Android 14, Samsung OneUI 6.1
I also used various software, such as Rui, Duck, and others who have the functionality to connect to webdav. The result is the same everywhere. I can see the file structure of the webdav folder, but I can't change/write/rename anything.
Please solve my problem.
I really need a working version of webdav.
bs8 wrote: ↑25 Mar 2025, 02:14
By default, the WebDAV list for shared folders is empty, indicating full permission. This means that the “*” you added might be interpreted either way. Therefore, it is advisable to confirm whether your “*” signifies “deny” or “allow”.
If you continue to encounter issues, please contact technical support for assistance.
bs8
Post by bs8 »
TMzethar wrote: ↑25 Mar 2025, 10:09
Yes, everything is specified correctly.
Screenshot: https://drive.google.com/file/d/1sRihxv ... sp=sharing
Translated from Russian, this is the “Edit Shared Folder” window.
Specifies
“client” = *
“permission” = allow
Return to “File Service”
