[Help] SMART Data for D2-320
blexter
Australia
Post by blexter »
I have a D2-320 with Hc550 16tb x2
I am unable to get the SMART data for these drives via my D2-320.
Is there a way to get this?
Re: [Help] SMART Data for D2-320
D2-320 supports the transmission of S.M.A.R.T information. Could you please describe your usage environment?
blexter
Australia
Post by blexter »
I'm using it on Proxmox VE and whenever I connect it to my system it shows that smart data is unavailable.
It might be that the account you're using doesn't support viewing that information. You can try using sudo or switch to the root account with higher privileges.
TANAKA
Japan
Post by TANAKA »
How can I check the SMART data on a Windows system?
Frostbyte
Post by Frostbyte »
TANAKA wrote: ↑14 Mar 2025, 11:45 How can I check the SMART data on a Windows system?
I just came across this post: viewtopic.php?t=7692
GDragon
Poland
Post by GDragon »
1. Download CrystalDiskInfo
Visit the official link to download the software installer.
2. Install the Software
Double-click the installer and follow the setup wizard (default settings recommended).
3. View S.M.A.R.T Data
Launch CrystalDiskInfo. It will auto-detect the TDAS-connected drive and display real-time metrics like health status, temperature, and detailed S.M.A.R.T values.
TANAKA
Japan
Post by TANAKA »
I will try,thanks!
Return to “USB Series”
