[Help] Want to reinstall a TOS version were app cans be reinstalled !
chaumont
France
Post by chaumont »
Subject: There is no more "TOS re-install" item in the panel board:
I have a rough souvenir of having installed "the last of the last" TOS version on my F2-221. Now (and it's too late) I think I remember this "last of the last" TOS installation was blocking future updates (and worse future apps installation).
Very stupidly, I have uninstalled (a too rapid manipulation) my Plex server and it is now impossible to reinstall it (even manually).
So, how can I re-install an older TOS in a more flexible version, or how can I upgrade TOS to a TOS5 version, more flexible?
Note: I need a brutal solution (since nothing of all my tests work).
Without my Plex server running, I am very sad :-(.
Re: [Help] Want to reinstall a TOS version were app cans be reinstalled !
What version of TOS are you currently using?
The issue may not originate from the system itself; it could be due to HDD errors, file system issues, or incorrect configuration of Plex library files.
If you can still access the TOS web interface, please refer to this troubleshooting guide:
viewtopic.php?t=4772
viewtopic.php?t=364
chaumont
France
Post by chaumont »
The version is TOS 4.2.07-2012241608.
I do not think it comes from HDD errors of a file system issue.
All the other apps have the same problem.
See image:
None of the recommendations below are feasible (most items have disappeared).
This issue might be caused by damaged system files. If you want to reset the system to lateset TOS 4 -- TOS4.2.44, please refer to:
viewtopic.php?t=423
Return to “Plex Media Server”
