504 Gateway Timeout
c3o2it
Italy
504 Gateway Timeout
Post by c3o2it »
Good morning... I can no longer access the NAS remotely. When I enter the address "https://myname.tnas.link/" it gives me the error "504 Gateway Timeout"
What do you think is the problem?
Noah
Australia
Re: 504 Gateway Timeout
Post by Noah »
you can try reinstallation
Not, you do not need to reinstall the OS. try to disable and then enable again the TNAS.online service. If the issue consistent, please update your OS to the latest version.
kstingel
Australia
Post by kstingel »
TMroy wrote: ↑10 Mar 2025, 21:36 Not, you do not need to reinstall the OS. try to disable and then enable again the TNAS.online service. If the issue consistent, please update your OS to the latest version.
Device Model: F2-423
TOS Version 6.0.530-00148
Not quite latest version I know, I'm trying to recreate dropped connections after upgrading from TOS5
reactivating TNAS.online fails upon entering email - apparently [email protected] style emails are invalid
trying [email protected] hasn't worked either
kstingel wrote: ↑31 Mar 2025, 03:15
Verifying...
Please contact technical support via your email, and we will further verify the issue.
kstingel wrote: ↑31 Mar 2025, 03:15 apparently [email protected] style emails are invalid
FYI: viewtopic.php?p=41810#p41810
ajkaramba
Germany
Post by ajkaramba »
I also get 504 Gateway Time-out every 2 weeks on my F4-423. Only a hard reboot is solving this issue.
Jellyfin also doesn*t work and gives the same error. SSH with putty also gives "Connection refused."
A thing to add: I'm trying to login via the IP-address + Port.
Return to “Network”
