Viewing retention value
Once you create a task and save it, how do you view what value was entered for number of retention backups?
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
D4-320
Re: Viewing retention value
For managing backup versions, you can access the following page to perform operations.
As for the number of versions to retain, you can view and modify it when editing the task.
Thanks, I see what it was, I had to enter the password on the first dialog box before I go get to the next one.
D4-320
D4-320
Similar thing happens in Rsync backup tasks. Maybe an option just to view the settings would work.
