Hello
I would like to know if the terramaster nas provide this functionality (NUT)?
Or whether this functionality will be planned in the future?
thank you
Re: I would like to know if the terramaster nas provide this functionality (NUT)?
Server or client?
Client is working already
Although not explicitly stated, the underlying UPS functions within TOS appear to be based on NUT (server & client).
Frustrated Beta Tester!!!
And they won't tell you where the REAL configuration files are (Been there, tried that!)
FYI I did a bit more checking. TM have used the 'imaginative' name for the ups of 'ups'
Using basic NUT commands from cli elicits the following:
[.........~]# upsc -c ups@localhost
192.168.155.227
127.0.0.1
[........ ~]# upsc ups@localhost
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.mfr.date: 2020/06/13
battery.runtime: 20100
battery.runtime.low: 120
battery.temperature: 22.9
battery.type: PbAc
battery.voltage: 27.7
battery.voltage.nominal: 24.0
device.mfr: American Power Conversion
device.model: IBM UPS1500THV
device.serial: AS0733210431
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: APC HID 0.96
driver.version.internal: 0.41
input.sensitivity: low
input.transfer.high: 257
input.transfer.low: 200
input.voltage: 234.7
output.frequency: 50.3
output.voltage: 234.7
output.voltage.nominal: 230.0
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.firmware: 601.1I1.I
ups.firmware.aux: 8.1
ups.load: 0.0
ups.mfr: American Power Conversion
ups.mfr.date: 2007/08/14
ups.model: IBM UPS1500THV
ups.productid: 0002
ups.serial: AS0733210431
ups.status: OL
ups.test.result: No test initiated
ups.timer.reboot: -1
ups.timer.shutdown: -1
ups.timer.start: -1
ups.vendorid: 051d
