Not able to login from a new Computer
suresh
Post by suresh »
I bought a new Desktop and trying to connect to my tnas using Windows File Explorer. I keep on getting wrong password message even though I am giving corrrrect password.
I am able to login with same credentials using browser, but not able to connect using File Explorer - to drag and drop files. Please help me.
Thanks.
Suresh.
Re: Not able to login from a new Computer
In TNAS check individual permissions on shared folders.
TMlinda
Post by TMlinda »
{L_BUTTON_AT}suresh
What is your TOS system version? If the guest user is enabled, you can deactivate this user first. You can also refer to the following operation link to troubleshoot:viewtopic.php?f=77&t=2759
suresh
Post by suresh »
All,
Thank you for your suggestions, but somehow none of them worked.
Finally it worked when I changed my password.
Thank you.
Return to “File Services”
