[TOS4]Why can't I log into the TOS webpage while other services such as Samba can be accessed normally?
TOS system configuration
Troubleshooting
Applicable models:
All TNAS models
Applicable version:
TOS 4.1.x ~ 4.2.x
Solution:
A. Log in to the TNAS terminal with ssh as root, execute the following instrcution:
service nginx start
Refresh the TOS page.
B. If method A does not solve the problem, please excute the following instruction:
service nginx stop
cp /etc.default/nginx/nginx-extend.conf /etc/nginx
cp /etc.default/nginx/nginx-http.conf /etc/nginx
cp /etc.default/nginx/nginx.conf /etc/nginx
service nginx start
Refresh TOS page
c. If method b does not resolve the issue, it is recommended that you reinstall TOS to fix the problem. Additionally, even if method b resolves the issue, the cause of the error is still unclear, and there may likely be other underlying problems. For stability and security reasons, we still recommend that you reinstall TOS.
viewtopic.php?t=423
Leon67
Re: Why can't I log into the TOS webpage while other services such as Samba can be accessed normally?
Post by Leon67 »
I have the same problem on F4-423 TOS 5.0.166, but the recommendations did not help. what else can be done?
Do you use any features and apps? What did you do to cause this to happen?
If you can't log in with ssh, restart TNAS and still the same result, you need to reinstall the system: viewtopic.php?f=76&t=423
Leon67
Post by Leon67 »
This problem arose after a regular reboot of the system. I reinstalled the system and so far everything is working fine.I installed and then uninstalled some regular applications, perhaps the problem arose because of this.
greenal
Post by greenal »
Bit of a long shot, but my Win11 desktop will not find TNAS while my VPN is on.
sybarix
Post by sybarix »
Had the same issue several times on the F2-221 running 5.0.158 and 5.0.171. Nginx was also unable to start after a regular system reboot.
