After more than 300 days of dedicated development and collaboration by hundreds of engineers, TOS 7 is here as the world's first AI-native NAS operating system: smarter, friendlier, and more refined. It brings more than 50 new features and over 1,000 detailed optimizations, delivering faster response, smoother interaction, and a more polished interface. TOS 7 opens a new era of intelligent storage. As the world's first NAS operating system deeply adapted for AI scenarios, it breaks down the operational barriers of traditional NAS systems, enabling complex storage management, system configuration, and service deployment through natural language. It truly upgrades NAS from a passive data repository to an active intelligent assistant.
Learn About the New TOS 7: https://terra-master.com/pages/tos7
Promotional video:
Applicable Version:
TOS 6.0.0794. (This update is not applicable to TOS 7 Beta users. TOS 7 Beta users should refer to the corresponding update guide.)
Currently, only manual updates are supported; the update has not been pushed yet.
Applicable Models:
Models that can be updated directly:
F2-422, F2-221, F5-221, F5-422, F5-421, F4-421, F4-221, F4-422
F2-425, F4-425, F4 SSD, U4-500
F6-424, F4-424 Max, F6-424 Max
U12-500 Plus, U8-500 Plus, T12-500 Pro, T9-500 Pro
Special Notes:
For F8 SSD and F8 SSD Plus users: Before updating, first update the system to 6.0.794. The firmware will be updated during the system update. If you installed 6.0.794 directly using an installation package, please manually update once again; otherwise, you may encounter the issue described in this post: viewtopic.php?p=49723#p49723
For F2-223, F2-423, F4-223, F4-423, T6-423, T9-423, T12-423, U4-423, U8-423, and U12-423 users: If your system is currently installed on, or you plan to install it on, an M.2 NVMe SSD, please follow the guide to adjust the BIOS boot order before updating: viewtopic.php?t=9417.
For F2-424, F4-424, and F4-424 Pro users, please read this post before updating: How to Properly Install and Use TOS 7 on the 424 Series TNAS
For F4-425 Plus and F2-425 Plus users, please read this post before updating: How to Properly Install and Use TOS 7 on the 425 Series TNAS
For T9-450, T12-450, and U8-450 users, before updating, migrate the system disk from the NVMe M.2 SSD to an HDD. Otherwise, after the update, the device will return to the system installation page. If the device fails to boot, remove the USB boot device and power it on again.
Warnings:
1. This update applies only to TOS 6.0.794. It does not apply to TOS 7 Beta users. TOS 7 Beta users should refer to the corresponding update guide.
2. TOS 7 uses a new permission management method. After updating, permission conversion is required, and automatic conversion is recommended. This process may take a long time, so please wait patiently. For example, 400,000 folders may take about 3 hours.
3. After updating, in addition to storage pools and volumes in normal use, Storage Manager may display several damaged storage pools and volumes caused by abnormal operations in TOS 6, such as directly removing disks. If you confirm they are no longer used, you can delete them directly.
4. After the system update, files maintained by the system in the root file system will be consistent with the TOS 7 installation package, and some built-in files and tools will be removed. Therefore, if an application that depends on PHP 7.4 cannot be opened after the update, go to App Center and install the PHP 7.4 dependency required by that application. Affected software includes: Web Server, VirtualBox,Tailscale, FreshRSS, Joomla!, MantisBT, MyBB, Net2FTP, MyWebSQL, Nextcloud, e107_cms, elFinder, IBOS, MariaDB, phpBB, Oray Pgyer, phpMyAdmin, WordPress, ZenTao, and Xunlei.
5. This version does not yet support system disk hibernation. Data disks can hibernate, and system disk hibernation will be implemented in a later version.
6. The VMs virtualization solution has been launched at the same time, and VirtualBox maintenance will soon be discontinued. To ensure the best user experience, users who are still using VirtualBox are advised to migrate their existing virtual systems to the VMs app within one month after the official release, so they can benefit from better performance and long-term technical support.
Notes:
1. In theory, the update will not affect hard disk data, but for safety, be sure to back up important data.
2. If your shared folders were generated by the Snapshot application, you need to reconfigure permissions after the update.
3. After the update, existing share links, desktop messages, recent access records, application logs, system logs, and SMART test schedules will be cleared.
4. After the update, the resource dashboard, navigation bar icons, and Debug mode will be restored to the system defaults.
5. Due to changes in security protocols, some applications need to be updated or reconfigured after the update, and community applications may need to be downloaded and installed again.
6. If you have modified the BIOS boot order, before updating, adjust it so that the TOS system disk has priority over USB drives and other boot devices. Otherwise, the device may enter the system installation interface again after the update.
7. TOS 6 system configuration cannot be restored directly to TOS 7. After updating, back up the configuration again.
8. After the update, all remote mounting functions (such as SMB, NFS, and WebDAV) will be migrated to the Remote Folder module in the lower-left corner of File Manager for unified management and connection. Existing mount tasks will remain unaffected.
9. After the update, ISO shared folder mounting will be migrated to File Manager. You can click an ISO file directly in File Manager to mount it without additional operations.
10. After the update, email push notifications for some functions will not be enabled by default. If you need to receive email notifications, go to General Settings > Notifications > System Notifications to enable them.
11. If the update gets stuck at 9%, please wait 1–3 minutes. If there is still no response after 10 minutes, simply refresh the browser.
12. Before updating, make sure your primary volume, usually volume1, has at least 3 GB of available space. Insufficient space may cause the update to fail.
13. After the update, the device IP address may change. Please use the TNAS PC client to search for and connect to the device again.
How to Update to TOS 7
Manual Update:
1. Download the update package: TOS 7.0.0747 (MD5:ba39bd4b7df89998d12af118beb3eba9)
2. Go to TOS > Control Panel > General Settings > System.
3. Under Manual Update, upload the update package.
4. Click Apply.
5. After the system update is complete, refresh your browser.
6. After the system update, your TNAS IP address may change. If you cannot connect to your TNAS using the previous IP address, use the TNAS PC client to search for the new IP address again.
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS mobile 3.5.077 for Android. (You can also search for "TNAS mobile" in the app store to install.)
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
Bug Reports:
We greatly appreciate your support. Should you need to report a bug, please send its description, reproduction steps, and screenshots to the following email: [email protected].
TOS 7 Is Now Out of Beta — Official Release
Re: TOS 7 Is Now Out of Beta — Official Release
I'm just trying to get my head around the bios requirements (or not) of different models.
Is there any chance you could link in .pdf versions of these notes -
especially the linked pages for bios updates - so than we can actually have the whole thing to hand to read in case of need.
I am a bit confused (more than normal
) trying to differentiate between the notices given in the control panel concerning available updates and then finding that update might not actually be a correct path to follow.
{And then, my F5-221 with latest Tos6 version, prescribed os partition size and suitable Bios (presumed) does NOT tell me the update to TOS7 is available.}
Note to Users:
Check the release notes carefully AND confirm your BIOS version (if applicable) BEFORE you follow update instructions from the Control Panel.
Note to Users:
F2-221 TOS7.0.1422 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1422 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
7.0.0.747? not 746?
https://support.terra-master.com/posts/ ... ease_Notes
F4-423
Yes this update applies only to TOS 6.0.794. It does not apply to TOS 7 Beta users
The version numbers are used to differentiate between versions of TOS so that users of different versions can know more clearly which installation package they need to use.
Great suggestion! I'll generate a download link for the PDF document.
No system update has been rolled out yet, and only manual update is available. We plan to begin a phased rollout in a few days.
For users already running the TOS 7 beta system, please refer to the following update guide: viewtopic.php?t=10179
- fallenazazel
will the F6-424Max need changing the boot order as other 424 models? Its in the list of applicable models but not within the specific guides for year models.
Is this version compatible to F2-223? I have updated it to TOS 7 but the network connectivity loss after awhile.
I have to ask this, why wait until the day TOS 7 is released and out of beta to inform folks that certain models need an BIOS update and/or BIOS settings changed in certain situations. Seriously unless this was discovered in the last few days, why not communicate this a few weeks ago.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1422
F6-424 at 7.0.1422 as well
D4-320
D4-320
