Target Users:
Users currently running TOS 7.0.0601 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions .
Important: This update is only applicable to TOS 7.0.0601 Beta and newer. Users with older versions must first upgrade to 7.0.0601 before applying this update.
Warning:
1、If you are unable to open File Manager after the update, please go to the App Center to update it.
2、You need to check whether your TNAS fully meets the requirements for the TOS official version. If it does not, you can refer to the solutions or make a note of them to avoid problems later.
3、After a system update, files maintained by the system in the root file system will be aligned with the TOS 7 installation package, and some built-in files and tools will be removed. Therefore, if an application fails to open after the update, please go to the App Center to install the PHP 7.4 dependency required by the application. Affected software includes: Web Server, VirtualBox, Tailscale, FreshRSS, Joomla!, MantisBT, MyBB, Net2FTP, MyWebSQL, Nextcloud, e107_cms, elFinder, IBOS, MariaDB, phpBB, BeiRui PuGongYing, phpMyAdmin, WordPress, ZenTao, and Xunlei.
Here, we sincerely thank @Lex, @rfbjr, @crisisacting, @imranalam, @snapsh0t, @Gremlin, @joka388, @storageninja, @Dennis_H, @Zymphad, @polen, @DekkaR, @sianderson, @Takeiteasy, @OneMany, @Tessi, @Nitrokalel, @pablomon69, @usersky, and @joergurmel for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Update Notes
Bug Fixes:
1. Fixed an issue where iniparse was terminated abnormally during system startup.
2. Fixed an issue where the USB marker changed after restarting TOS.
3. Fixed an issue where the last three hard drive slots could not be properly recognized on F4-221, F4-421, F4-422, F5-221, F5-421, and F5-422 models.
4. Fixed an issue where an administrator could access other users' unlocked Safe Box.
5. Fixed an issue where downloading files failed when selecting all files.
6. Fixed an issue where refreshing the page was sometimes required after deleting message notifications.
7. Fixed an issue where joining an AD domain via IP and advanced settings prompted a failure.
8. Fixed an issue where the navigation bar occasionally displayed sorting anomalies in weak network environments.
9. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS mobile 3.5.077 for Android. (You can also search for "TNAS mobile" in the app store to install.)
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
TOS 7.0.0746 Official Release (X86) is Now Available
Re: TOS 7.0.0746 Official Release (X86) is Now Available
Thanks for the Final version update.
Still necessary to update from v6 to v7 using a beta 601 build first?
Also the release notes https://support.terra-master.com/posts/ ... ease_Notes page is not updated yet.
All three updated no issues. Testing in the morning
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
D4-320 & D4-SSD
You can update directly from TOS 7.0.0601 Beta to TOS 7.0.0746. Thank you for the correction. The release notes are still being added.B0rg wrote: ↑23 Jun 2026, 09:52 Thanks for the Final version update.
- crisisacting
- Silver Member
Upgraded testbed without a hitch. Will continue testing & hopefully will be able to implement/deploy upgrade strategy for clients in coming weeks.
Hello!
I have F4-424 Pro 32 Gb
Can I put this release on blank discs?
To clarify: which version OS will the installer download when installed on a clean NAS?
F4-424 Pro: 32GB RAM | BIOS: MADN0101.V07 | TOS v 7.0.0777
F6-424 on version 6.0.794
When checking for updates. It says no updates are available. Does it needs to be manually updated with the software package file?
EDIT: Nevermind, just re-read the original post. Didn't read it tidy.
Updated succesfully no data loss on volumes. f6-424 max f4-424 max
Stuck on 9% for 1 hour now, any suggestion what to do now?
The installer will download TOS 6.0.794, then you may follow our instruction to upgrade to TOS7
viewtopic.php?t=10183
