OpenClaw Beta – Early Access
rfbjr
Re: OpenClaw Beta – Early Access
Post by rfbjr »
I've installed OpenClaw on my F4-424 Pro, but now trying to decide which LLM to use, my intent is to experiment with various automation tasks on the NAS. Does anyone have any recommendations? The usage would be in spurts and as time permits.
F4-424 Pro (x2) at 7.0.1298
Unless you're working on some complex development projects, the performance difference between different models in OpenClaw isn't that significant, really.
rfbjr
Post by rfbjr »
TMroy wrote: ↑19 Sep 2026, 01:19 Unless you're working on some complex development projects, the performance difference between different models in OpenClaw isn't that significant, really.
Thanks, So I'll then just look for the most cost efficient, aka cheapest.
vitali
Belarus
Post by vitali »
Any chance to see latest updates for openclaw version? Can it be updated by user or it should come as a new version from system app center?
EriChan
Post by EriChan »
vitali wrote: ↑08 Oct 2026, 07:05
OpenClaw updates are distributed through the TOS Application Center.
To ensure system compatibility, authentication service integration, and data safety, updates should be installed directly via the App Center rather than manually upgraded in the backend.
We are currently working on adapting newer versions and will release an update in the App Center once testing and validation are complete.
Thank you for your patience and support!
rfbjr
Post by rfbjr »
EriChan wrote: ↑08 Oct 2026, 09:45
Glad to hear, since Rosie (OpenClaw) said xxx was a bug and asked if she should look for an update. I declined for now. :)
