OpenClaw Beta – Early Access
hurhan001
Post by hurhan001 »
Dear TerraMaster Users:
We are excited to announce that OpenClaw is now available for one-click installation on the TOS system. No complicated deployment or command-line operations are required, allowing you to quickly explore OpenClaw’s features.
Please note that this is an early access version and may have functional limitations and stability issues. It should not be used for important data storage, production environments, or business-critical scenarios.
Compatible TOS Versions
TOS 7.0.0485 Beta or later
Important Notes
1.This is an early access version and may contain unknown issues and stability risks. Do not use it in production environments or for important data.
2.Installing this application should not affect existing data on the hard drive. However, we strongly recommend backing up important data before installation.
3.This application has elevated privileges. Please avoid high-risk operations such as system modifications, disk formatting, or bulk permission changes.
Installation and Usage Steps
1.Manually download the OpenClaw installation package (MD5: f3343ae6f3a0762c10bafd908bcbe212)
2.Go to TOS → App Center, select Manual Installation, upload the package, and follow the on-screen instructions
3.After installation, follow the instructions in the official forum to configure the large model and set up OpenClaw
4.If the installation fails, please try again
Bug Feedback
Thank you for taking the time to help us test. Your feedback helps us improve the product.
As this is a beta version, issues are expected. We recommend reporting bugs through official channels with a description, reproduction steps, and relevant screenshots.
Contact: [email protected]
Nitrokalel
Mexico
Re: OpenClaw Beta – Early Access
Post by Nitrokalel »
perfecto la descarga esta miu bien y este es el camino correcto para que terramaster avance
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
izedgrudged
Post by izedgrudged »
Looking forward to seeing how it improves with community feedback!
Nitrokalel
Mexico
ya lo instale, ya lo conecte a mi n8n, ya le di acceso a nextcloud, ya lo integre con mi api de openai y esta jalando muy bien sin problemas, sin cosas complejas, hace todo solo,.... la recomendo y estoy pensando en darle control del propio nas para que lo optimize, la app la he instalado en un F8 SSD Plus :D :D :D
D1 SSD (2TB, prod)
To enable better orchestration of AI agents, TOS 7 is rapidly advancing towards AI integration. Transforming TOS 7 with AI capabilities involves much more than simply installing OpenClaw. Enabling AI agents to effectively interact with TOS and perform operations correctly and accurately requires a substantial amount of work. Stay tuned for upcoming updates.
rfbjr
Post by rfbjr »
I'm retired now, well going on for 2 years. So I never used AI for my work (Mainframe programmer/Desktop Support/Windows & Linux Admin). Well I did ask "AI" to generate some WebSphere configuration commands. What I nightmare that was. :D
Are there practical examples of how to use OpenClaw with TOS 7. Do I need anything else to complement OpenClaw?
F4-424 Pro (x2) at 7.0.1298
MikeZhang
Post by MikeZhang »
rfbjr wrote: ↑20 May 2026, 21:14
Please follow our instruction to configure it viewtopic.php?t=9925&p=55517#p55517
MikeZhang wrote: ↑20 May 2026, 22:07
For a large leap forward in computing, ( :lol: ) it is necessary to dive backward into terminals and command language :?: Really :?:
Just to say "Hello".
I was programming in terminals before Windows 3 was a "thing" (yes, I retired before @rfbjr).
To say I am anti-AI is rather too broad, but I am pushing back on the intrusion into my life from all avenues supposedly "AI".
First thing I did was to remove the Nav bar icons and the login page "bumpf".
What could Open AI-give me that I can't possibly get elsewhere? It seems that the only truth is that AI systems will COLLECT information REGARDLESS.
I'll give you this for consideration: (rather long)
https://www.youtube.com/watch?v=YUpxgdd ... R3b0NlbnRz
rfbjr
Post by rfbjr »
I’m going to wait before installing OpenClaw. Once I see practical examples of how i can use it to improve on certain aspects of TOS 7. Also I’m not signing up for a openAI plan before I even know why I need it.
Update: I'm not trying to be negative, I just want to see a spark of an idea/usage before I give this a try.
I don't need my own personal AI assistant, any more than I have inadvertently, from other tools.
jpeckinp
Post by jpeckinp »
rfbjr wrote: ↑20 May 2026, 23:07 I’m going to wait before installing OpenClaw. Once I see practical examples of how i can use it to improve on certain aspects of TOS 7. Also I’m not signing up for a openAI plan before I even know why I need it.
I would have to second this thought.
Somebody on here has to have some examples of what we would use it for.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
