Is it normal?
This forum serves as a free discussion zone, intended to facilitate community conversations on topics unrelated to TerraMaster products and services.
akaserge
Is it normal?
Post by akaserge »
Good day. Is it normal that system partition "/" occupies 94%? TOS 6 on F2-221 model. Thanks in advance.
Model F2-221 TOS Version 6.0.794
Re: Is it normal?
94% of what, would be the question. If your os partition is not 8GB (7.6GB approx actual) you should not really be running TOS6.
Phil
Re: Is it normal?
Post by Phil »
akaserge wrote: 23 Mar 2026, 01:54 Good day. Is it normal that system partition "/" occupies 94%? TOS 6 on F2-221 model. Thanks in advance.
On the F2-221 model running TOS 6, a 94% system partition ("/") usage is abnormal, indicating the system may crash due to running out of space or enter read-only mode.
You need to log in to the TOS web interface, go to Storage Management > Snapshots, and delete all unnecessary old snapshots. If Docker is installed, clean up unused images and containers. Please clean up the occupied space as soon as possible (especially logs and snapshots).
akaserge
Re: Is it normal?
Post by akaserge »
Phil wrote: 23 Mar 2026, 18:57
I don't use system snapshots. Only 2 containers are used (transmission and jackett). What can i clean up more and how? Thanks.
TMnight
Re: Is it normal?
Post by TMnight »
akaserge wrote: 24 Mar 2026, 00:05
You can open the Terminal from the TOS desktop and run the following commands to check the disk usage of directories under the root path, in order to identify any abnormal space consumption:
cd /
du -sh ./*
For example, check whether there is a directory named volume1 (lowercase) (do not confuse it with Volume1).
If you confirm that this directory contains abnormal or unintended data, you can first copy its contents to a valid volume for backup:
cp -r ./volume1 /Volume1/public
After verifying that the data has been copied correctly, you can delete the original directory under the root path to free up space.
akaserge
Re: Is it normal?
Post by akaserge »
TMnight wrote: 24 Mar 2026, 08:55
cd /
du -sh ./*
As I can see, only 2 directories have a huge size - path (5.1G) and usr (1.7G)
Should I delete them completely? What commands should I use for this? Thanks.
Phil
Re: Is it normal?
Post by Phil »
akaserge wrote: 24 Mar 2026, 14:24
cd /
du -sh ./*
Based on the screenshot you provided, the /usr directory must be retained, and its size is normal.
You should review the /path directory yourself and confirm that its contents are unnecessary before deleting it. If you are unsure of its origin, the safest approach is to keep it temporarily or move it to another location for observation, rather than deleting it directly.
If you still have questions about the directory’s contents, we recommend backing them up first.
Deletion command (for the /path directory; use with caution)
If, after verification, you decide to delete all contents within the /path directory (please ensure there is no important data in /path beforehand), you can use the following command:
rm -rf /path/*
akaserge
Re: Is it normal?
Post by akaserge »
Thanks all for the help. This was a directory with folders from transmission. When installing in docker, I incorrectly specified the paths for saving data. The "/" partition is now only 26% full.
Return to “Lounge and Boast”
