[Help] Docker won't start
Discussion about Docker
evgeniybolnov
Post by evgeniybolnov »
Hi all!
After update to TOS 7.0.0408 docker engine won't start
F2-423
TOS 7.0.0408
Docker Engine 27.2.1.003
What i found:
> /Volume1/@apps/DockerEngine/init.d/service start
rm: cannot remove '/etc/default/docker': No such file or directory
cp: cannot stat '/Volume1/@apps/DockerEngine/sbin/6.12.41+/veth.ko': No such file or directory
> uname -r
6.12.41+
> ls /lib/modules/6.12.41+/extra/
dev_handlers  iscsi-scst.ko.xz  isert-scst.ko.xz  scst.ko.xz
> tree /Volume1/@apps/DockerEngine/sbin
├── 5.15.59
│   └── veth.ko
└── 6.1.58+
    └── veth.ko
In start function on docker engine service file(/Volume1/@apps/DockerEngine/init.d/service):
    KERNEL=$(uname -r)
    EXTRA="/lib/modules/$KERNEL/extra/veth.ko"
    if [ -e $EXTRA ]; then
      cp $EXTRA /lib/modules/$KERNEL/kernel/
    else
      cp $docker_path/sbin/$KERNEL/veth.ko /lib/modules/$KERNEL/kernel/
    fi
    depmod > /dev/null 2>&1
    modprobe -r veth
    modprobe veth
Where can I find the required kernel module or roll back the kernel version? Or what other solutions might there be to this problem?
MikeZhang
Re: [Help] Docker won't start
Post by MikeZhang »
evgeniybolnov wrote: ↑03 Mar 2026, 16:15
We sincerely apologize for any inconvenience caused! Our lab tests have confirmed that the relevant functions are working correctly. To resolve your issue as quickly as possible, we suggest you first try restarting your NAS device, or uninstalling and reinstalling Docker. If neither of these steps resolves the problem, you can schedule remote assistance through our online chat interface on our website. Our engineers will then thoroughly investigate and resolve the issue for you.
evgeniybolnov
MikeZhang wrote: ↑03 Mar 2026, 18:40
I tried rebooting and reinstalling Docker Engine.
I was offered a file to download in the chat and given a link, but I don't have access to that resource. After that, I was sent to this forum =)
Return to “Docker”
