[HELP] can't set permissions for usbshare  [SOLVED]
Metrogeek
Post by Metrogeek »
F4-425 PLUS on tos 6.0.794. I'm trying to modify permissions for usbshare. Right now everyone has access, when i go to control panel/usb device/permission everyone is checked on allow but all is greyed out and can't be modified.
I don't want everyone to access my usbshare, what iam missing?
Thks
Re: [HELP] can't set permissions for usbshare  [SOLVED]
Unfortunately, the permission feature is only supported when the file system format of the USB drive is EXT4.
If your USB drive uses a file system format such as NTFS or FAT32, you will not be able to edit permissions.
Metrogeek
Post by Metrogeek »
Make sense, thanks for the clarification
