TOS 7.0.0403 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @EgorA, @Gremlin, @rfbjr, @ZiRo, @samius, @joka388, @red454, @usersky, @OttO1916, @wander1236, @mnewland, @SunDogBC and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where message notifications might display abnormally in specific scenarios.
2. Fixed an issue where CPU sorting might be incorrect in specific scenarios.
3. Fixed an issue where some directories in remote folders might not be fully displayed under certain conditions.
4. Fixed an issue where the sharing page might display abnormally.
5. Fixed an issue where transferring large files might fail during remote access.
6. Fixed an issue where traffic control rules for Wi-Fi interfaces might disappear after toggling OVS.
7. Fixed an issue where shared folders might not display properly in the control panel under specific scenarios.
8. Fixed an issue where OVS could still be turned off after running VMs when a BOND had already been created.
9. Fixed an issue where images in directories containing quotation marks could not be indexed.
10. Fixed other known issues.
Warning:
If you are using USB Copy, please go to the App Center to update Storage Manager and USB Copy; otherwise, the auto-mount function will not work.
If you are using virtual machines (VMs), please do not update yet and wait for us to update the related applications.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.506 for Windows OS.
2. Download TNAS PC 5.2.506 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.506 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
PeteBest
Re: TOS 7.0.0403 Beta (X86) is Released for Update
Post by PeteBest »
I don't understand why the support team ignores the issue I encounter, still in this build iteration.
I have attached two pictures -one before using the TNAS Android app - normal operations and another - after the TNAP app did a search for a TNAS device on the subnet.
The result - the device gets clogged up with TNAS demon tasks and becomes unusable.
Please expedite the remediation of the issue.
Pete
PeteBest wrote: ↑03 Feb 2026, 18:21
Hello, are you referring to the TOSDaemon generated by searching for NAS through TNAS mobile? Please generate and download the log report in TOS > Technical Support > Issue Report, then send it to our technical support email. We will analyze it. Also, please include the link to this post in the body of your message.
F2-221 Updated. Appears to be OK, no issues with update.
Note update to ClamAV, but no actual release note(s) to identify changes.
Note:
No particular issues with searching network (Android 16 device) and logging into NAS (on updated device). TOSdaemon running 1 instance @ 17% (approx) cpu. (Just my old brain getting to grips with GUI :( )
@PeteBest: Which TNAS Mobile version are you running? Have you updated Mobile version to recommended?
Frustrated Beta Tester!!!
alexivanov
Post by alexivanov »
Good afternoon. Installed TOS 7.0.0299 on F8 SSD Plus using this link viewtopic.php?t=9437 .
The system was installed without errors. After installation, the system asked to upgrade to the latest version. Go to TOS > Control Panel > General Settings > System > Update, and click "Check for updates." The status says "Couldn't check for updates. The TNAS device is not connected to the Internet." The Internet is available on the device. Tell me how to fix this or where to download the latest version of TOS 7.0.0403 Beta (X86) to update manually.
rfbjr
Post by rfbjr »
F4-223 and F4-425 Plus updated without issue. Hibernation settings are turned back after update.
Testing will continue.
F4-424 Pro initial update did not work. Screen shot attached:
Unit is pingable, but putty will not connect.
Will have to force power off unit and then back on.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
rfbjr
Post by rfbjr »
Ok putty issue was my fault. The system came back up no initial messages on HDMI console. But like other updated, the journald was 99%. I uploaded the system report. Going to reboot again, this time gracefully.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
rfbjr
Post by rfbjr »
2nd reboot no difference with the journald. System is running and responding normally. I updloaded the system report after the gracefull reboot. No HDMI console errors.
The Rsysnc job I ran so far, the webgui doesn't show the job start time, it does show the end time stamp.
Now I see HDMI errors. Oh well.
Completely different, The image upload process (I will double check again) does not like to upload photos from OneDrive.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
DMagister
Post by DMagister »
Terra Search and Global Search open empty window. The same on previous build too.
p.s. sorry, this issue for reverse proxy connection only. for direct connection it's working.
rfbjr
Post by rfbjr »
3rd reboot and all is fine. I'll upload system report once it's finished being created.
Nevermind, posting image from One Drive is fine.🤷‍♂️
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
