[Share] Personnal Vault block the Onedrive CloudSync ?  [SOLVED]
totoguile
France
Post by totoguile »
I've configured cloudsync with 2 Onedrive account : one is working perfectly, the second one stop to sync (telling that sync is terminated) just after 2 folders.
After checking, the working account had no Personnal vault configured, while the other one had it, ... and was in 3rd position on the list.
I've checked if I can sync specific folder and not "/" of this onedrive account, and it works perfectly.
I strongly suspect that CloudSync is not able to "bypass" the Onedrive Personnal vault : is it possible to fix this ? could it be possbile to check which specific folders we want to sync per cloudrive account ?
totoguile
France
Re: [Share] Personnal Vault block the Onedrive CloudSync ?
Post by totoguile »
CloudSync seems to be based on rclone.
an issue has been open on their side to https://github.com/rclone/rclone/issues/8736
the shorterm conclusion is to add --exclude='/Personal Vault/**'
Thank you for your feedback. I will first relay it to the testing team for internal testing.
totoguile
France
Post by totoguile »
One remark : "Personnal Vault" may have different names (depending of the your language).
In FR , for example, it is "Coffre-fort"
Re: [Share] Personnal Vault block the Onedrive CloudSync ?  [SOLVED]
Thank you for your reminder. This is a known issue, and we will resolve it in a subsequent version. Please wait for the release of the new version.
totoguile
France
Post by totoguile »
Hi, do you have an ETA for a new version of cloudsync that will solve the Personal Vault issue ?
totoguile
France
Post by totoguile »
Hi could you move this thread into feature request or should I re create it ?
Return to “CloudSync”
