[Help] Potential hack or UI glitch? UI showing scrambled/corrupted characters (TOS7)  [SOLVED]
Cimmerio
Spain
Post by Cimmerio »
Hi everyone,
I’m writing because I encountered a very alarming situation today when trying to log into my TerraMaster NAS. I'm concerned about whether this is a security breach or a system failure.
As you can see in the attached screenshot, the entire TOS user interface is displaying unreadable symbols and scrambled characters. I cannot read any menu options or navigate the settings properly.
My setup and details:
NAS Model: F6-424 Max.
TOS Version:TOS7 Penultimate update
What I've tried: I have cleared my browser cache and tried accessing the NAS from different browsers and devices, but the issue persists.
File Status: I can still access my files via SMB and they seem fine.
Cimmerio
Spain
Re: [Help] Potential hack or UI glitch? UI showing scrambled/corrupted characters (TOS7)
Post by Cimmerio »
I've verified that this only happens on my usual computer, using different browsers and even in incognito mode. However, when accessing it from another computer, the interface displays correctly.
Re: [Help] Potential hack or UI glitch? UI showing scrambled/corrupted characters (TOS7)  [SOLVED]
Hi.
If you are using Windows, your computer is likely using a less common encoding for non-Unicode parts. You can try enabling 'Beta: Use Unicode UTF-8 for worldwide language support'.
Cimmerio
Spain
Post by Cimmerio »
It seems it was an isolated error on my computer (although I'm not sure). It hasn't happened again.
Best regards and thank you.
