Configure camera with 2 lens
A CCTV monitoring and recording application
shanny
Italy
Post by shanny »
i'm newer in TOS. I bought my NAS one month ago and i try to set up it the best i can (with my friend Google :D )
Yesterday i installed Surveillance Manager and i connected my camera Imou Cruiser 8MP (that has 2 lens) with ONVIF protocol
The software recognizes the camera and connects it, but only using 1 lens, not 2 lenses.
How can i do to recognize the second lens?
also, there is no way to change the storage folder to another directory other than the default ones (Surveillance, public etc.)
thank you all
crisisacting
Re: Configure camera with 2 lens
Post by crisisacting »
shanny wrote: 14 Dec 2025, 07:02 … installed Surveillance Manager and connected my camera Imou Cruiser 8MP (that has 2 lens) with ONVIF protocol
Despite having two cameras, the firmware on that unit only has ONVIF support on the Pan+Tilt camera.
There's a discussion regarding it & frigate @ https://github.com/blakeblackshear/frig ... ions/11848, which alludes to that single camera ONVIF.
shanny
Italy
Post by shanny »
Thanks a lot, I managed to set up the PT lens with ONVIF and the Fixed Lens with RSPT. it was enough to add the first lens with ONVIF and then the second lens with RSPT, as if it were a second camera. They work great!!! Is there a way to change the storage directory instead?
You can change the recording storage location here:
Surveillance - Camera - Edit - Storage
shanny
Italy
Post by shanny »
Thanks, but I've already tried it from there. The problem is that I have two HDDs and I want to move/record to the second HDD. The program only allows me to select system folders (such as public, Photo, etc.). Thanks in advance.
You can first create a storage pool and volume using the second hard drive, then create a shared folder located on this volume, and finally select this shared folder in the storage location options.
Return to “Surveillance Manager”
