[Help] Issue with Hybrd d8
keyzersuze
Australia
Post by keyzersuze »
Hi
Bought 3 of these , I have them filled with 4 x 3T drives . they are connected to dell 1ru server
and running proxmox. problem is when i reboot my servers - when the kernel load - slot 3 dies - I have to whilst its rebooting unslot and re slot slot #3 for it to be seen
Re: [Help] Issue with Hybrd d8
Hi.
Is this issue occurring on one of the D8 Hybrids?
What phenomenon would occur if you swap the HDDs in Slot3 and Slot4?
Would a similar situation occur if you connect this D8 Hybrid to another computer/server?
keyzersuze
Australia
All 3 suffer and I have replaced slot 3 a few times I thought the drives were faculty. Then I worked out it was the enclosure.
Are you using the original C to C cable? If you are using a non-original cable, please use the shortest possible cable or add an active USB hub to enhance the signal.
Return to “USB Series”
