TOS 6.0.794 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.770 or later versions.
Note:
If your TOS version is TOS 5, please refer to the TOS 6 update instructions first
Here, we sincerely thank user vitali,B0rg,Ludovic,addx972,mmick,bartmans99,billyBob and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue that prevented connection to some OpenVPN servers.
2. Fixed an issue that prevented the generation of thumbnails for some video files.
3. Fixed an issue that could cause errors when transferring a large number of files via SMB on macOS.
4. Fixed an issue that prevented the installation of TOS when the BIOS time was abnormal.
5. Fixed issues with the UPS.
6. Fixed issues with the SPC.
7. Fixed an issue that could prevent the system from booting according to the scheduled power plan.
8. Fixed issues with TNAS.online.
9. Fixed other known issues.
10. Optimized the boot process, which reduced the boot time.
11. Updated the firmware for the F8 SSD / F8 SSD Plus.
12. Updated the system certificates.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.506 for Windows OS:
https://download3.terra-master.com/App ... 2.506.exe
Download TNAS PC 5.2.506 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .2.506.pkg
Download TNAS PC 5.2.506 for macOS (ARM architecture):
Download TNAS Mobile 3.4.023 for Android:
https://download2.terra-master.com/TNAS ... .4.023.apk
TNAS Mobile for iOS: Download from the iOS App Store.
FredMutter
France
Re: TOS 6.0.794 (X86) is Released for Update
Post by FredMutter »
RyanYang wrote: ↑02 Dec 2025, 12:01 3. Fixed an issue that could cause errors when transferring a large number of files via SMB on macOS.
Update done without any problems.
And you should do more tests with MacOS: Every new version brings new solutions and new problems too :-/
DCCentR
Post by DCCentR »
RyanYang wrote: ↑02 Dec 2025, 12:01 12. Updated the system certificates.
What date should the new certificates have? Currently, it is as follows:
It was the same before the update.
athurdent
Germany
Post by athurdent »
Is that applied automatically and what is the change log / fix? I had to update PCIe firmware manually in the past ( viewtopic.php?p=49736#p49736 )
Is this the same update, now integrated or does it update something else? How do I check if it applied correctly, like I could with the update linked above?
athurdent wrote: ↑02 Dec 2025, 13:32
Yes, the firmware update included in this system update is the same one you previously performed manually. Therefore, there is no need to repeat the update. The method to verify whether it was applied successfully matches exactly what was described in the post you referenced—you can confirm it just as you did last time.
DCCentR wrote: ↑02 Dec 2025, 13:29 It was the same before the update.
This certificate update is only visible in certain scenarios, so your certificates likely renewed automatically even before this update.
rfbjr
Post by rfbjr »
Updated my F4-223 seems fine so far. The update dialog box only got to 9% then I heard the unit beep. I assumed the update was complete.
Waited a few minutes and refreshed the browser. All is fine.
Next is the F4-424 Pro but a bit later.
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
athurdent
Germany
Post by athurdent »
RyanYang wrote: ↑02 Dec 2025, 13:57
Thanks, update of an F8 SSD went fine.
sianderson
Post by sianderson »
F2-424 updated successfully
my F2-423 is running some long processing tasks at the moment but should be complete by the weekend so will update when its complete
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
rfbjr
Post by rfbjr »
Ok F4-424 Pro updated, no issues.
LUN was reattached to the Windows client after this NAS was rebooted.
D4-320 & D4-SSD
