Docker Engine installs to wrong Volume
Tallicia
Post by Tallicia »
I have moved applications from /Volume1 to /Volume2 by uninstalling them and ensuring the
App Center -> Settings -> The location where applications are installed is set to /Volume2
But, Docker Engine keeps re-installing to /Volume1
How can I ensure that this installs to /Volume2 like other apps do after they have been uninstalled from /Volume1. :?
Is there a command line way to install the tpk and ensure that it is installed to /Volume2? :?:
Tallicia
Re: Docker Engine installs to wrong Volume
Post by Tallicia »
FWIW, On the fifth attempt, I uninstalled, rebooted, and then installed and it did install to the correct /Volume2 location.
rigveda
Post by rigveda »
It seems to be similar to the problem I had here:viewtopic.php?t=9533
So did you have to reboot the NAS service multiple times for the "/Volume2" location to hold?
Tallicia
Post by Tallicia »
This one has been running without reboot since the last update to the TOS version, so "holding", but without rebooting, that's inconclusive.
CloudSync still needs to move, but it is planned to relocate to a different TNAS
It is currently unclear whether the restart is related to the effectiveness of the position modification. This issue involves the latest version of TOS 6 and the test version of TOS 7, so we need further testing.
Return to “Others”
