TerraSync 2.x not available on TOS 6.0.783
theAgony
Italy
Post by theAgony »
Hi, I have encountered an issue on 1 of my 3 TNAS.
First, I own 2 F2-424 and 1 F4-424 Max.
I have updated every of the 3 at TOS 6.0.783, but on just one of the F2-424 the app center can't update, so the terrasync client (and server) available version is still 1.3.930 (latest must be 2.0.005)...
The NAS is online and everything works fine, except the version of the available app.
To fix it, I have downloaded the 2.0.005 package from the the other TNAS and manually installed on the defective NAS.
But, I am wondering if there is something I can do to permanently fix the issue.
As now, the TerraSync Server on the MAX and the clients on the 2 F2-424s are working, but I fear the next update of TOS...
Thank you.
A.
TMbuddy
Re: TerraSync 2.x not available on TOS 6.0.783
Post by TMbuddy »
theAgony wrote: ↑03 Oct 2025, 05:28 Hi, I have encountered an issue on 1 of my 3 TNAS.
Thank you.
A.
Hello! From your description, this is definitely an abnormal phenomenon, and as you mentioned, the other two units are functioning normally. May I ask if your F2-424 is able to update properly now? Also, is your network connection working correctly? If the issue persists, you can visit the TerraMaster official website to contact our online support. We will provide you with remote technical assistance.
theAgony
Italy
Post by theAgony »
Hello!
the defective F2-424 is online (I can reach it through tnas.online and TerraSync works over internet), but the TerraSync app in the app center is still outdated (version 1.0.930).
I was wondering, is there a way to force app center update (without any lost of data of course...)?
Thank you.
theAgony
Italy
Post by theAgony »
or maybe I have to open a particular PORT on the Firewall?
Return to “Others”
