TOS 6.0.783 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.770 or later versions.
Note:
If your TOS version is TOS 5, please refer to the TOS 6 update instructions first
Here, we sincerely thank user FredMutter、thierrys73、sianderson、jpeckinp、ORION、OttO1916、Arendatr、seb、Claus、AlexanderSO、Gremlin、billyBob 、johntomadakane、rfbjr、crisisacting、drakey83 、samius、mmick and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed the issue that remote file sharing via TNAS.online might fail in some regions.
2. Fixed the issue that macOS users could not properly access the system using guest accounts.
3. Fixed the issue that the system might fail to shut down during array synchronization.
4. Fixed the issue that deleting users might not work correctly after importing thousands of users.
5. Fixed some issues with SPC.
6. Fixed some issues with WebDAV.
7. Fixed some issues with storage manager.
8. Fixed some issues with the App Center.
9. Fixed some issues with File Manager.
10. Fixed some issues with media index.
11. Fixed some issues with SMTP.
12. Fixed some issues with network services.
13. Fixed other known issues.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.325 for Windows OS:
https://download3.terra-master.com/Apps ... .2.325.exe
Download TNAS PC 5.2.325 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .2.325.pkg
Download TNAS PC 5.2.325 for macOS (ARM architecture):
Download TNAS Mobile 3.4.023 for Android:
https://download2.terra-master.com/TNAS ... .4.023.apk
TNAS Mobile for iOS: Download from the iOS App Store.
Note:
Update Notes
Bugs fixed:
Update Procedure:
Re: TOS 6.0.783 (X86) is Released for Update
FYI: updates installed one by one 694 -> 770 -> 783
All volumes (and pool) were lost after 783 was loaded, system asked me to create new ones. I rejected this and manually rebooted system again. All volumes returned back, data is ok. Perhaps it will be a big problem if somebody will agreed with system proposal and creates new volumes (and new pool) at first load on version 783.
Upon receiving your feedback, our lab promptly conducted a retest to replicate the issue. Analysis indicates that this phenomenon is likely due to certain disks not being recognized in time during the system update and restart process.
Therefore, we recommend you try the following steps:
1. Check whether the disk tray is securely fastened with screws and ensure the disk is fully locked in place. You can try reseating the disk and then restarting the device.
2. It is advised to enable Debug Mode in the "Support & Help" section of the system before restarting. If the anomaly occurs again after restarting, further analysis can be performed using the debug logs.
If the issue persists, please feel free to contact us, and we will assist you as soon as possible.
I got the same probleme/fix in 770.vitali wrote: ↑22 Sep 2025, 18:23 FYI: updates installed one by one 694 -> 770 -> 783
storageninja
Hello is this release properly beta and alpha tested? This topic is the GA release, right?
GA release.
F8 SSD updated fine, coming from 6.0.770.
- luismartin
Phew, every new update is a risky venture.
There are always brave people (thanks) who dare to share their experiences.
I think I won't update until I've verified that everything works properly and there's no risk of data loss.
Just updated an F2-423 running 770, with an attached D4-320, with no issue. All volumes intact at reboot.
F2-423 TOS 7.0.1536 20GB RAM, 2x NVMe drives (.25TB + 1TB JBOD as Volume1), 2x 12TB TRAID as Volume2 D4-320 4x 8TB TRAID as Volume3
- nedhedrick
F5-221 updated fine, from -770 to -783, volumes are OK after update.
