[Help] can we use Crucial 8GB DDR5-4800 SODIMM in F4-424 max
dsedusol
India
Post by dsedusol »
Hi
Crucial 8GB DDR5-4800 SODIMM ram is compatible for f4-424 max nas can we use this ram?
Re: [Help] can we use Crucial 8GB DDR5-4800 SODIMM in F4-424 max
The memory specifications you mentioned are theoretically compatible. However, choosing non-official memory may carry compatibility risks. To ensure optimal stability and performance, we strongly recommend using certified memory that has undergone official rigorous testing.
You can view the list of verified compatible memory here:
https://www.terra-master.com/global/compatibility/
If you have already purchased other memory modules, you may also refer to community discussions or user feedback to learn about actual compatibility experiences.
dsedusol
India
Post by dsedusol »
I am not purchasing to any ram but I will purchase to DDR5 ram for my f4-424 max nas so where to buy in India.
Perhaps you could visit their official website to inquire or search for relevant memory modules on online shopping platforms.
darkmakers
Australia
Post by darkmakers »
For anyone itnerested I used 2 x 32GB Crucial DDR-4800 on in F4-424 Max which worked fine, however to fit with the included heatsink I had to shave away some of the plastic on the side of the cover. In the end I just cut out the diamond shaped piece of plastic on the side and covered it with mesh.
stranik170
Post by stranik170 »
I want to warn you that the Crucial 32GB DDR5 4800MHz SODIMM 1.1V CL40 CT32G48C40S5.M16A1 memory is not suitable for F4-424 Max. My F4-424 Max did not start. When turned on, it made short intermittent beeps (1-2 seconds) and the TERRAMASTER logo did not appear on the monitor screen. If you return the native memory, the F4-424 Max starts, one short beep is heard and the TERRAMASTER logo appears on the screen.
stranik170
darkmakers wrote: ↑02 Dec 2025, 09:32 For anyone itnerested I used 2 x 32GB Crucial DDR-4800 on in F4-424 Max which worked fine, however to fit with the included heatsink I had to shave away some of the plastic on the side of the cover. In the end I just cut out the diamond shaped piece of plastic on the side and covered it with mesh.
Please specify the model of the memory module that you have installed. I read your post and bought a Crucial 32GB DDR5 4800MHz SODIMM 1.1V CL40 CT32G48C40S5.M16A1 memory for the F4‑424 Max, thinking that this memory would work on my F4‑424 Max, but the F4‑424 Max did not recognize the memory and did not start.
TMjack
Post by TMjack »
After replacing the memory module, the system requires approximately 3 to 5 minutes to perform a BIOS memory verification during startup. If there is still no response after waiting for an extended period following power-on, it indicates that the memory module is incompatible with the device.
