Clam AV
Re: Clam AV
How and which directories should I select for scanning if all checkboxes are active in the settings.
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: Clam AV
The images you upload is very fuzzy, not possible to read. would you resend again?
- sianderson
- Silver Member
Re: Clam AV
you are aware if you click on the images they display in full screen? certainly not fuzzy here they appear crystal clear
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: Clam AV
Sorry, you have encountered this issue. I have recorded it in the repair checklist.
Re: Clam AV
I suspect that it has frozen and has been scanning this file for a day or more, and I ran a full scan of all disks.
Re: Clam AV
You can enter the top command in the terminal to view the current system's running processes. If there is a risk with the hard disk, this phenomenon may also occur.
