[Share] remote access via domain
AntoxaS
Post by AntoxaS »
Good day!
I connect to NAS from external access http://nas.kineetic.ru everything is fine. But when I want to make an external link to a photo I get a local address http://192.168.1.178/******** How can I configure it to get an external link?
Re: [Share] remote access via domain
You can replace the LAN IP and port part with the tnas link. If you are using TOS6, you can customize the generated remote link in 'File Modification'.
AntoxaS
Post by AntoxaS »
TMzethar wrote: 05 Aug 2025, 19:28 You can replace the LAN IP and port part with the tnas link. If you are using TOS6, you can customize the generated remote link in 'File Modification'.
I use TOS6. I didn't quite understand where to change it. Write in more detail
SugarOuYang
Post by SugarOuYang »
Hello, you can complete remote image sharing by following the steps shown in the screenshot below. The specific operation is: after creating the share, right-click on the "My Shares" page to copy the remote sharing link.
AntoxaS
Post by AntoxaS »
No, I need to get a link for external access as a domain, but I only get a link of the IP type
AntoxaS
Post by AntoxaS »
for example on sinology you can do it like this
TMLila
Post by TMLila »
AntoxaS wrote: 06 Aug 2025, 13:23 No, I need to get a link for external access as a domain, but I only get a link of the IP type
Hello! Please first confirm that your DDNS configuration is correct and has been successfully enabled. After enabling it, we recommend re-sharing the required image. In the 「My Shares」 module, select the sharing link of this image, click Edit, and verify that the address of the remote sharing link is in the form of a domain name. Once the address is confirmed to be correct, simply select and copy the remote link.
AntoxaS
Post by AntoxaS »
I tried through the Duckdns service, when copying the link it asks to enable TNAS Online.
And if I turn on TNAS ONLINE, I get a link like this: https://tnas.online/****
Please edit any existing share and change the 'tnas.online/TNASID' part of the remote link to 'DDNS/WAN IP + mapped port' (e.g., ttyy2349.duckdns.org). After that, all your future shares will automatically use this custom remote link.
Return to “Network”
