[Help] My D4-300 in not recognized by my windows installation
Vtechlg
Post by Vtechlg »
My D4-300 in not recognized by my windows installation, all the light are fine, if i plug it to my mac it work perfectly, currently when plugged into my windows installation it thinks that its a RAID controller and also show a Unkown USB Device (Set Address Failed) in the device manager.
Vtechlg
Re: [Help] My D4-300 in not recognized by my windows installation
Post by Vtechlg »
It was working just fine prior to a failed windows update.
TMbuddy
Post by TMbuddy »
Vtechlg wrote: ↑03 Aug 2025, 01:34
Hello! Your device works fine on Mac, so the device itself is normal. Consider other factors. What file system format are you using on Mac? It might be using a format that Windows doesn't support. If you're using a Windows-supported file system format, maybe it's a connection issue.
Please try changing USB ports, replacing the USB cable; try backing up data and reinitializing to see if it reads normally; update USB drivers.
Return to “USB Series”
