[Help] Portainer reinstall
Discussion about Docker
vignatiev
Post by vignatiev »
Hello! I've moved all my apps from Volume 1 (hdd) to Volume 3 (ssd). I've fully uninstalled Docker Engine, Docker Manager and Portainer apps. When I've reinstalled them, I cannot login to Portainer again. First page on new Portainer is Login instead Create admin user. Last auth creds shows login error.
How can I resolve this? There are no folders at old path - `Volume1/@apps`, except `.Snapshot`.
Can I install Portainer with default (linux) way via terminal?
F4-424
Re: [Help] Portainer reinstall
Please check if there are any Docker-related folders under Volume 1 directory. If there are, delete them. Additionally, you can clear your browser cache and re-enable Docker.
Jeanieang
Bahamas
Post by Jeanieang »
vignatiev wrote: ↑15 Jul 2025, 00:01 Hello! I've moved all my apps from Volume 1 (hdd) to Volume 3 (ssd). I've fully uninstalled Docker Engine, Docker Manager and Portainer apps. When I've reinstalled them, I cannot login to Portainer again. First page on new Portainer is Login instead Create admin user. Last auth creds shows login error.
Can I install Portainer with default (linux) way via terminal doodle jump?
You could try removing any Portainer volumes or persistent data manually before reinstalling. Installing via terminal with the official Linux method should work and might bypass the issue.
Return to “Docker”
