[Help] Hypercache issue
luismartin
Post by luismartin »
Has any bug been reported using a RAID 5 configuration with Hypercache? I have a 12-drive RAID 5 (TOS 6.0.694), and if I enable Hypercache (Balanced mode) the first few times the NAS boots, it boots fine. However, on the fifth or seventh boot, the disks become very active for a couple of hours after booting.
The md0_raid5 process also has a very high activity level. If I disable Hypercache, this doesn't happen.
I've tried disabling and re-enabling Hypercache several times, but the result is always the same.
MikeZhang
Re: [Help] Hypercache issue
Post by MikeZhang »
Please generate and download the log report package in TOS > Technical Support > Report Issues, and then send it to support at terra-master.com for inspection with cloud drive sharing link. (WeTransfer, Onedrive, Apple, GoogleDrive...)
This may enable us to determine the problem more accurately and quickly
