ClamAV Scan Schedule not working
Vertebrae0296
Ukraine
Post by Vertebrae0296 »
I have ClamAV scheduled to run weekly:
Device: TNAS-7999
TOS Version: 6.0.694
ClamAV Version: 1.4.003
But ClamAV never runs automatically. It says it is going to, but then never does unless I run the scan manually. Why isn't the automatic job running?
This has been broken for at least the past several version. Potentially always in V6
MikeZhang
Re: ClamAV Scan Schedule not working
Post by MikeZhang »
Please uncheck first and second options, only enable 3rd one, check again if it works.
elantris
Post by elantris »
Is this ever going to be fixed? I have a TNAS F2-425 and you can clearly see the scheduled scan is not running.
I told it to start at 19:05 and the time passed and ClamAV did nothing.
It will not scan nor will it update the database. The log files are completely empty unless I manually run the scan.
This problem looks to be quite old. Is Terramaster ever going to address this?
Device: TNAS F2-425 | TOS Version: 6.0.794
elantris wrote: ↑12 Jan 2026, 11:08
Which TOS version are you using?
{My installation appears to be running, but I have set up a test run for this morning to verify.}
Frustrated Beta Tester!!!
We are trying to reproduce the situation you mentioned.
Could your TOS version information and Clam AV version information be the same as those of Vertebrae0296?
If they are not, please let us know so we can better locate the issue.
I have one nas where the OS and Clamav versions match. Other machines are running TOS7
elantris
Post by elantris »
Here is my system information:
Device: TNAS F2-425
The screenshot from my earlier post got mislaid. I have added it back.
elantris
Post by elantris »
You can see in my photo the last time this ran was on Dec 20, 2025. That's when I manually ran a scan. Since then, it has never triggered as scheduled.
Thank you for the supplementary information. We are currently troubleshooting the issue. If you have more discoveries to supplement, please tell us here.
Return to “Others”
