[Help] SMB Connection Drops on macOS 15 - Need Help! (F4-424 Pro, TOS 6.0.694)
Hi everyone,
I'm using a TerraMaster F4-424 Pro running TOS 6.0.694-00165 with several Macs on macOS 15.5, and I'm having persistent SMB connection issues that are driving me crazy. Hoping someone here has found a solution!
My SMB connections keep dropping randomly - I get the "spinning wheel" in Finder, Adobe Illustrator, and InDesign for about 60-90 seconds, then everything works again. The weird thing is that a Windows 11 machine connects to the same NAS perfectly with no issues at all.
I've been reading through this forum and tried pretty much everything I could find:
- Disabled the Recycle Bin on shared folders (saw TMzethar's recommendation)
- Turned off SMB Multichannel, Opportunistic Locking, and Durable Handles
- No USB drives connected to avoid any kernel panic issues
- Applied all the VFS fruit settings for better Mac compatibility
Ping works fine even during the disconnections
Same network works perfectly with a Synology NAS
I previously had an issue where created files would appear grayed out which that has been fixed with the latest TOS version but this problems with the smb connection dropping makes it pretty much unusable.
Current SMB settings on TOS
vfs objects=fruit streams_xattr
fruit:metadata=netatalk
fruit:resource=file
fruit:locking=none
oplocks=no
durable handles=no
force create mode = 0664
force directory mode = 0775
force group = allusers
Any help appreciated, thanks!
fruit:resource=file
fruit:locking=none
oplocks=no
durable handles=no
Re: [Help] SMB Connection Drops on macOS 15 - Need Help! (F4-424 Pro, TOS 6.0.694)
We recommend contacting technical support via email at suppor(at)terra-master.com or through the Official Live Chat, providing them with a system report for analysis.
- FredMutter
Model: F2-424 with TOS 7.0.0777 Bios V08
Thanks for the link, I hadn't seen it. I actually haven't had this problem with the synology but I guess maybe it's because we use it differently than the TNAS now. Will try some of the proposed solutions to see if it helps.FredMutter wrote: ↑26 Jun 2025, 15:17Did you read this ?
https://discussions.apple.com/thread/25 ... ortBy=rank
I have issues too with latest MacOS 15 ( Apple silicon ), worked flawless until latest updates. I opened a ticket to terra mater but no resolution answers yet. I can connect to SMB share on my terramaster, I can read files but I cannot write . If I crate a new folder I got "untitled folder with a no access symbol in it
and I Cannot remove it unless I do it from terminal in web gui... never seen something like that. I can connect in NFS from Linux without issues.
Last info , with Windows 11 no issues at all...
Tried to change username with capital letters, no changes.
Your issue may be related to permission settings. I sincerely apologize for the delayed email response. For your convenience, I've also addressed this matter in your other forum post.
To ensure we can assist you promptly, could you please:
Share your email address with us, or resend your inquiry to our support team
We truly appreciate your support of TerraMaster and thank you for your patience. Please don't hesitate to reach out if you need any further assistance.
I tried the solutions from the other posts, it seems a bit better but the connexion still drops a few times a day
I'll contact tech support to see if they can help.
We have conducted verification tests in the laboratory regarding the issue you mentioned, but we haven't been able to replicate the situation where the SMB automatically disconnects as you described. You can use the online chat on our official website or make an appointment via email to schedule a remote session with our engineers, so that they can conduct a further examination for you.
