[Help] Plex won’t recognise USB drive / Can’t create USB Shared folder
Terrariaria
Austria
Post by Terrariaria »
I have multimedia on my USB drive that I’m trying to add to my Plex library.
Plex will only allow me to add libraries in my HDD shared folder. There doesn’t seem to be any way for me to create a shared folder on the USB drive.
This seems like a big issue. Is there no way for me to get Plex to use my USB drive as a library?
Re: [Help] Plex won’t recognise USB drive / Can’t create USB Shared folder
Hi. You can usually find the directory of the USB drive here and add it to the Plex index.(TOS5/TOS6)
/Volume1/@usb/usbshare1
If this is not your issue, please let us know.
Terrariaria
Austria
TMzethar wrote: 12 Jun 2025, 20:55 Hi. You can usually find the directory of the USB drive here and add it to the Plex index.(TOS5/TOS6)
Plex can see "/Volume1/@usb/usbshare1" but then when I open that folder Plex cannot see any of the media folder or media files that's inside the USB drive.
It just thinks /Volume1/@usb/usbshare1 is totally empty and cannot see any folders or files inside it.
https://imgur.com/a/5Xq7CMx
The 'plex' user has Allow permission to access the USB drive.
Terrariaria
Austria
I was able to solve this by doing "chmod -R 777 '/Volume1/@usb/usbshare_sda1/Plex'".
Is there some setting that can fix this going forward so I don't have to chmod 777 everytime media is downloaded from sonarr/radarr?
Hi. We are verifying the relevant issue you mentioned. We will try to optimize it so that you can perform related authorization actions on the page.
Terrariaria
Austria
USB drive folders/files can't be read by Plex (Even with permission allowed) unless you do chmod 777
Return to “Plex Media Server”
