[Help] Virtual Box / PHP
Yann75
France
Post by Yann75 »
I have a brand new TOS 6 6.0.694 installation and I tried to Virtual Box official package 7.0.2..0.1012. Installation took a while (for a few minutes, VirtualBox appeared in the Application Launcher but not in the list of installed packages)
When I try to access the interface, I received the PHP error message already referenced in some other threads but not suggestion works.
An unknown PHP error occurred. This is most likely a syntax error in config.php in phpVirtualBox's folder. The most common errors are an unclosed quote or a missing semicolon in a configuration item that has been entered (e.g. location, username, or password).
Depending on your PHP configuration, navigating directly to config.php in your web browser may display the PHP error message.
A click on the link (/virtualbox/config.php) in the error message lands on another error:
502 Bad Gateway
nginx/1.18.0 (Ubuntu)
The php-fpm.conf file seems ok, with my account configured in the listen.user and listen.group.
Any suggestion / fix ?
Yann75
France
Re: [Help] Virtual Box / PHP
Post by Yann75 »
Done some debugging
1/ Not sure why php-fpm was not running. Started it manually, not sure if it will come back automatically after reboot (can't do it now)
2/ There are errors in the Nginx configuation file: the path to unix sock file in nginx.conf and php-fpm.conf refer to unix:/run/php/php-fpm.sock but unix:/run/php/php7.4-fpm.sock seems to be the correct path
After manually "fixing", I get the login / password screen of VBox ... but admin/admin mentioned in the installation details doesn't work
Hi.
This may help you solve the issue:
viewtopic.php?t=5858
Yann75
France
Post by Yann75 »
Thanks. Unfortunately I have a different issue. The user/group where properly set to my username, not root. Also the /etc/init.d/php-fpm no longer exists, probably a change with TOS 6
Thank you for providing more information, it is clear that this is a new phenomenon.
Please first observe if there is RAID synchronization or unusually high CPU/RAM usage.
Try restarting the NAS to attempt to restore normal operation.
If the issue persists, we recommend contacting Live Chat to schedule an engineer for remote troubleshooting.
Return to “Virtual Machines”
