Move to/Copy to shortcuts  [Accepted]
Already accepted requirements or suggestions.
koalakoala
Australia
Post by koalakoala »
Hi, If possible can you add the following shortcuts to move/copy to? thanks in advance,
a. Favorites shortcut, once pressed show them in 'directory list'
b. HDD shortcut, once pressed show the HDD's in the 'directory list']
c. search shortcut to find a specific folder
Also, can you add a dropdown arrow icon to sort the files from A/Z - new/old
MikeZhang
Re: Move to/Copy to shortcuts
Post by MikeZhang »
koalakoala wrote: ↑28 May 2025, 14:08
Hi, this requirement is recorded, please wait for our tech team to verify.
You can click "Name" or "Size" to rearrange display order.
koalakoala
Australia
Thanks MikeZhang, much appreciated
koalakoala
Australia
MikeZhang wrote: ↑28 May 2025, 14:23
Just tested this on TOS 6.0.694.... No, "Name" or "Size" are not clickables. Also Size does not show the size of folders. It seems only works for files.
Thanks again.
OrionXie
Saudi Arabia
Post by OrionXie »
koalakoala wrote: ↑29 May 2025, 12:31
Here, clicking on 'Name' or 'Time Modified' will sort the folders and files within this folder, and modification time can also be sorted.
koalakoala
Australia
OrionXie wrote: ↑29 May 2025, 16:06Here, clicking on 'Name' or 'Time Modified' will sort the folders and files within this folder, and modification time can also be sorted.
Thanks but this post refers to the "move to/ copy to" workflows. Try to move/copy a file/folder.
These actions " clicking on 'Name' or 'Time Modified' are not supported in the "Select a directory" window.
The A-Z or alphabetically order issue can be seen on the left side. It seems TOS sorts the folder alphabetically - but for volumes-. This is why I suggested the changes described in my original post.
Thanks again
Understood. Your requirements have been added to the list for discussion.
koalakoala
Australia
TMzethar wrote: ↑30 May 2025, 04:53 Understood. Your requirements have been added to the list for discussion.
Thanks TMzethar , much appreciated
Return to “Accepted”
