Emby access without wifi
servit00
Italy
Post by servit00 »
Hello to all members. Only under wifi i can access my libraries. I set in terramaster f2-212 remote access but yet no work. Can anyone help me? Thanks
HeliaWu
Re: Emby access without wifi
Post by HeliaWu »
servit00 wrote: 25 May 2025, 00:50
Could you please provide your device model and system version? Additionally, would it be possible to share a screenshot of the page where remote access is failing?
servit00
Italy
Post by servit00 »
I have a nas terramaster f2-212 and from google pixel 9 pro XL i don't view libraries contents, only cover... What can i attach? I don't see error, only Black screen after click in cover. Many thanks
servit00
Italy
Post by servit00 »
HeliaWu wrote: 25 May 2025, 14:41
please help me. the advertisement is ACCESS DENIED. can you help me? thanks
servit00 wrote: 26 May 2025, 23:43
Regarding the libraries content and the black screen you mentioned, can you provide screenshots?
Does the issue only occur on your Google Pixel 9 Pro XL? Are you accessing it through a browser, or are you using the Emby client or another tool?
Return to “Others”
