i, when updating the F2-212 NAS from TOS version 5.1.17 to version 6.0.585, it remained stuck with the "installing update 0%" message box for a long time.
So I thought there was some problem. I turned off the NAS and it didn't work again.
Now it's in a continuous boot loop. The power LED comes on, the fan starts, the drives boot, and the loop starts again.
Is there any way to break it out of the loop?
I've already removed the battery, with no effect.
colud I create an USB for bootit using Bootloader? how i can prepare it?
Thanks.
[Help] F2-212 continuos reboot
Re: [Help] F2-212 continuos reboot
viewtopic.php?t=6433&hilit=initboot
Works like a charm & your data will survive
F5-221 - TOS7.0.1278 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1278 - 2x3TB JBOD - 1x4TB Single USB
- crisisacting
- Silver Member
That doesn't apply to the ARM based 212 series TNAS devices.OttO1916 wrote: ↑16 May 2025, 16:57 viewtopic.php?t=6433&hilit=initboot
Oops, my bad. I'm using x86 blinders. SCSIcrisisacting wrote: ↑16 May 2025, 21:33That doesn't apply to the ARM based 212 series TNAS devices.OttO1916 wrote: ↑16 May 2025, 16:57 viewtopic.php?t=6433&hilit=initboot
6.0.585 only supports TOS 5.1.73 and above for updates. Your 5.1.17 version does not meet the requirements.jduraper wrote: ↑16 May 2025, 16:34 i, when updating the F2-212 NAS from TOS version 5.1.17 to version 6.0.585, it remained stuck with the "installing update 0%" message box for a long time.
Thanks.
It is recommended to reinstall the 5.1.73 system and try to update again.
You can refer to this link in the forum: https://forum.terra-master.com/cn/viewtopic.php?t=3924
Hello, thaks for yours interest, how does CursaYang comented the TOS 5.1.17 was wrong, I was going from TOS 5.1.73 to 6.0.585. the big problem is all boot information is for x86 and by ARM there are nothing. If someone know how could connect via USB a Bootloader firmware?
Thanks for all
Thanks for all
Please upgrade TOS 5.1.17 to TOS 5.1.73 first
Then refer to the upgrade instructions of arm. I hope it can help you.
viewtopic.php?t=7888
