TMroy wrote: ↑18 May 2025, 14:18
If it’s confirmed to be a hardware issue with our gear, we’ll totally process an RMA for you — no problem at all. But right now, I’m not entirely sure what’s causing it. Mind sharing what device you’re using as your Ubuntu host? Maybe try testing the setup on a different computer or machine? Just wanna rule out if the problem’s with your current setup.
We’ve had several reports lately where the USB ports on NUC mini PCs are acting up — turns out it might be a hardware design flaw causing random glitches.
The device is a
Minix Z300. I have attached the TM-320 to my mac laptop in order to run DriveDx, and do some general tests (ZFS) and transfers, but running long-term that way is not a realistic option for testing.
Output of lspci is below, trimmed of a couple devices to fit in char limit.
Since the rebuild, it's been running without noted problems; time will tell.
The only other thing I can think of is that I couple times observed that while running under load, plugging in another drive produced errors. I cannot make any guess whether that would come from the host controller, or the TM hub.
00:00.0 Host bridge: Intel Corporation Device 4617
DeviceName: Onboard - Other
Flags: bus master, fast devsel, latency 0, IOMMU group 1
Capabilities: [e0] Vendor Specific Information: Len=14 <?>
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-N [UHD Graphics] (prog-if 00 [VGA controller])
DeviceName: Onboard - Video
Flags: bus master, fast devsel, latency 0, IRQ 161, IOMMU group 0
Memory at 6000000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable+ 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Capabilities: [320] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: i915
Kernel modules: i915, xe
00:0a.0 Signal processing controller: Intel Corporation Platform Monitoring Technology (rev 01)
Flags: fast devsel, IOMMU group 2
Memory at 6001120000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [d0] Power Management version 3
Capabilities: [100] Designated Vendor-Specific: Vendor=8086 ID=0002 Rev=1 Len=16 <?>
Capabilities: [110] Designated Vendor-Specific: Vendor=8086 ID=0003 Rev=1 Len=16 <?>
Capabilities: [120] Designated Vendor-Specific: Vendor=8086 ID=0004 Rev=1 Len=16 <?>
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0d.0 USB controller: Intel Corporation Device 464e (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 124, IOMMU group 3
Memory at 6001110000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=8/8 Maskable- 64bit+
Capabilities: [90] Vendor Specific Information: Len=14 <?>
Capabilities: [b0] Vendor Specific Information: Len=00 <?>
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.0 USB controller: Intel Corporation Alder Lake-N PCH USB 3.2 xHCI Host Controller (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 132, IOMMU group 4
Memory at 6001100000 (64-bit, non-prefetchable) [size=64K]
00:14.2 RAM memory: Intel Corporation Alder Lake-N PCH Shared SRAM
Flags: fast devsel, IOMMU group 4
Memory at 6001138000 (64-bit, non-prefetchable) [disabled] [size=16K]
Memory at 600113f000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [80] Power Management version 3
00:14.3 Network controller: Intel Corporation CNVi: Wi-Fi
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation CNVi: Wi-Fi
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 5
Memory at 6001134000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:16.0 Communication controller: Intel Corporation Alder Lake-N PCH HECI Controller
Flags: bus master, fast devsel, latency 0, IRQ 150, IOMMU group 6
Memory at 600113e000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [a4] Vendor Specific Information: Len=14 <?>
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 SD Host controller: Intel Corporation Device 54c4 (prog-if 01)
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 7
Memory at 600113d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
00:1c.0 PCI bridge: Intel Corporation Device 54bb (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 8
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 3000-3fff [size=4K] [16-bit]
Memory behind bridge: 80500000-805fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Device 0000:0000
Capabilities: [a0] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [220] Access Control Services
Capabilities: [150] Precision Time Measurement
Capabilities: [a30] Secondary PCI Express
Kernel driver in use: pcieport
00:1d.0 PCI bridge: Intel Corporation Device 54b0 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 9
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: 80400000-804fffff [size=1M] [32-bit]
00:1f.0 ISA bridge: Intel Corporation Alder Lake-N PCH eSPI Controller
Flags: bus master, fast devsel, latency 0, IOMMU group 10
00:1f.3 Audio device: Intel Corporation Alder Lake-N PCH High Definition Audio Controller
[removed for chars]
00:1f.4 SMBus: Intel Corporation Device 54a3
Flags: medium devsel, IRQ 16, IOMMU group 10
Memory at 600113c000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Device 54a4
Flags: fast devsel, IOMMU group 10
Memory at 80600000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
[details removed for chars]
02:00.0 Non-Volatile memory controller: Shenzhen Longsys Electronics Co., Ltd. Lexar NM610 PRO NVME SSD (DRAM-less) (rev 01) (prog-if 02 [NVM Express])
Subsystem: Shenzhen Longsys Electronics Co., Ltd. Lexar NM610 PRO NVME SSD (DRAM-less)
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 12
Memory at 80400000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [70] Express Endpoint, MSI 1f
Capabilities: [b0] MSI-X: Enable+ Count=9 Masked-
Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158] Alternative Routing-ID Interpretation (ARI)
Capabilities: [168] Secondary PCI Express
Capabilities: [1d4] Latency Tolerance Reporting
Capabilities: [1dc] L1 PM Substates
Capabilities: [1ec] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2ec] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Kernel driver in use: nvme
Kernel modules: nvme
