[Help] Add second Operating system drive.
I'm wondering how I would go about adding a second system drive. Currently I have a F4-424 (6.0.650) with 2 HD and 1 m.2 SSD. Currently the Disk Panel shows the system is only on the M.2.Can I add the system OS to either a installed drive or to a newly added drive or another M.2. I have not tried yet I thought I would get some direction before trying. Thank you in advance for any help. I did search but only found something sort of related but required linux skills which I do not have.
Re: [Help] Add second Operating system drive.
If I use the "keep data" What data does it keep? Do i need to redo all the disks/pools ,users and folder shares and installed apps.
If you are using TOS 6.0.650, resetting the system will not affect your data, but it will impact system configurations (including user lists and service configurations). As a precaution, if during the reinstallation process it prompts you to 'delete/format/lose' data, please stop the operation and contact us. Here are the detailed steps:
viewtopic.php?t=7178
Ok thank you for the information. I think I need to find a way to back up my configuration or write it down so I can get everything back the way it is. Data is one thing,It's easy to back up but all the time spent configuring my settings was alot. Again thank you for the helpful information
If you are re-installing the same TOS version no,
Control Panel > System > Configuration > Back up system Configuration
can be of some assistance.
Also Control Panel > User > More > Export
will give you a spreadsheet output of users and information BUT NOT PASSWORDS. (Similarly for User Group)
When importing 'Users', you can insert plain text passwords in the appropriate spreadsheet column which will work when imported. Individual users can then change this password or, if the facility has been enabled, treat the password as 'lost'.
These methods are not "all encompassing", but @TM are working on future improvements.
I would suggest, on restore, use the following order:
System Config - User Groups - Users
