[Help] cant get my tnas to resync
veryneedy
Post by veryneedy »
tos 6.0.577
model t9-450
i noticed my nas was bleeping the alarm today so i logged in and it says raid is degraded 85.25%
so i checked my drives in the control panel and they all saying heathly and present 1-9
i clicked to edit it and repair raid clicked next and hdd7 comes up
but if i click it and carry on it says all data will be erased so i click yes and then confirm it then confirms saved configuration but nothing else it still wont resync so is there somthing i am missing or should i replace disk 7 ?? with a new disk
Re: [Help] cant get my tnas to resync
Please first enable Debug mode in the Support & Help section on the TOS desktop and try fixing the issue again. If the problem persists, please download the log and send it to our technical support team, then disable Debug mode.
Next, try re-inserting the hard drive and restarting the TNAS. If the issue still remains, you can contact our technical support team for remote assistance.
If the hard drive shows as normal, the issue is typically fixable, but your case may require further inspection.
veryneedy
Post by veryneedy »
ok thanks for your reply i have done a report and treid again but the same thing happended it just said saved configuration and nothing
so i turned it off and rebooted still nothing
so i went out this morning and got a 22tb hard drive and turned off inserted that into 7 and tryed again
presently it says its rebuilding so i am hoping that will now be fixed can i get back to you if it fails thanks just abit worried as its still saying rebuilding 85.25% or is that because the disk is still rebuilding
