When using the D16 Thunderbolt 3 device on Windows 11, a blue screen issue may occur.
FAQs and instructions only for Thunderbolt series raid storage
Applicable Models
D16 Thunderbolt 3
Fault phenomena and solutions
If you encounter a blue screen problem while using the D16 Thunderbolt 3 device on Windows 11, it is recommended to rule out the following:
The D16 Thunderbolt 3 device does not support Windows Thunderbolt 4.
It is recommended that you use the device on a Windows Thunderbolt 3, MacOS Thunderbolt 4, or MacOS Thunderbolt 3 interface.
