[Help] TerraSync
TerraSync is a cloud drive service application that helps users build their own private cloud drive services with their TNAS devices.
AudrilDroid
Chile
[Help] TerraSync
Post by AudrilDroid »
Hello, dear community, I would like to ask for your help. I have an F2-212 with which I want to synchronize some devices, but my device does not have TerraSync installed, and I can't find the app to install it manually.
I also can't reinitialize my NAS since I have a little more than 12 TB of files on the system. Any ideas on how to resolve this?
Re: [Help] TerraSync
Hi. F2-212 does not support Terra Sync.
King7
Post by King7 »
I am new NAS player, I don't know how to do TerraSync settings. If there is any video or guide will be perfect. Looking forward....
TMeric
Post by TMeric »
King7 wrote: ↑03 Mar 2025, 18:03
You can refer to the TerraSync help documentation at the following link:
https://toshelp.terra-master.com/web/#/en/TerraSync
Hope this helps.
CathyW
Post by CathyW »
You device F2-212 can not use TerraSync . So you can check if use SMB can help you .
TMeric
Post by TMeric »
CathyW wrote: ↑07 Mar 2025, 14:39 You device F2-212 can not use TerraSync . So you can check if use SMB can help you .
Yes, the F2-212 is an ARM-based NAS and cannot run the TerraSync application. TerraSync is only supported on X86-based NAS, such as the 423 and 424 series.
rfbjr
Post by rfbjr »
TMeric wrote: ↑07 Mar 2025, 12:04
Hope this helps.
I'm considering using TerraSync, with TOS 7 in beta, is there a TOS 7 version of the document listed above?
F4-424 Pro (x2) at 7.0.1298
EriChan
Post by EriChan »
rfbjr wrote: ↑28 Mar 2026, 20:51
Yes, this is the TerraSync help documentation for TOS 7.
rfbjr
Post by rfbjr »
Great, thank you!
Return to “TerraSync”
