'RAID is degraded' F5-221
relaxa
Wales
Post by relaxa »
Yesterday I added a fifth disk to my RAID 5 array (TOS 5.1). After 20 hours of configuring I got this error:
I followed some instructions I found telling me to pull the drive out and re-insert it to make sure it was it was seated properly but that didn't change anything. The drive is showing as fine so I followed these instructions to try to repair the array. viewtopic.php?t=1545&sid=8c2da113d2a066 ... 1a32e358b4
But after I click Configure it just waits for a few seconds before saying 'Configuration saved!' and then I'm back to the 'RAID is degraded' page.
The volume itself seems to be working fine however.
Anyone have any idea?
Re: 'RAID is degraded' F5-221
We have not been able to locate the problem based on the information you have provided so far. Please generate and download the log report package in TOS > Technical Support > Report Issues, and then send it to support(at)terra-master.com for inspection.
If you can't send the zip package because it's too big, you can delete the following folders of the zip package to reduce the size.
etc>tos>scripts
etc>udev
etc>init.d
