USB Copy failed, but which file and why?
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
shadyabhi
Post by shadyabhi »
How do I know which file failed? There is nothing in UI or journalctl.
Re: USB Copy failed, but which file and why?
Generally speaking, you can find it in the log.
What is the information displayed in the log?
This task seems to only have one file, why can't it be found? Do you have any other relevant information to provide us with to understand the situation?
shadyabhi
Post by shadyabhi »
Cam you confirm the log i Should check?
You can check the logs here. When you hover over "Event", you can see the path of the file.
Return to “USB Copy”
