How to Upgrade f4-424 from tos5 to tos6
Hausmeier
Greenland
Post by Hausmeier »
Hey,
In another Thread I was adviced to upgrad TOS5 to TOS6 on my f4-424 as only tos6 can install packages in Linux as tos5 doesn't Support apt-get.
But I don't know how. In the System Management it always says that my Software is up to date. So what can I do? And can I used my installed Apps afterwards again?
Thanks in advance.
Re: How to Upgrade f4-424 from tos5 to tos6
Could you tell us which version you are currently running? Need a starting point ;)
Frustrated Beta Tester!!!
Hausmeier
Greenland
Post by Hausmeier »
Of course, I'm sorry.
It's the Version 5.1.145
The following link provides the full release notes for upgrading:
viewtopic.php?t=6984
but a lot of that probably won't be of interest to you. A direct link to the update package is in this post of mine from a few days ago. That thread is about a different model, but the process is the same. (Presume you never ran anything less than 5.1 on your F4-424).
Hausmeier
Greenland
Post by Hausmeier »
So I can Update directory to tos6 if i got it right as I have exactly tos 5.1.145 and am not in between. But do you know if my Apps are updated as well or do I have to Rennstall everything?
HeliaWu
Post by HeliaWu »
Hausmeier wrote: ↑22 Jan 2025, 07:05
Hello, updating TOS5 to TOS6 will not update your existing apps, you can manually update your apps after updating to TOS6.
Hausmeier
Greenland
Post by Hausmeier »
Ok but still not sure as I read the warning that All my configuration will be gone after that. So all the data on the nas Hdds and the raid1 I installed is all away?
TMlinda
Post by TMlinda »
Hausmeier wrote: ↑23 Jan 2025, 07:02
Hello, upgrading the system generally will not damage your data.
Hausmeier
Greenland
Post by Hausmeier »
Ok, thank you
Hausmeier
Greenland
Post by Hausmeier »
Well I updated but now I can't access the system via ssh anymore. Do you know why?
Return to “System Update”
